Booking Calendar Order
I’ve made a booking system for our meeting rooms and was using the Booking Calendar to display the current availability but There doesn’t seem to be a way to change the order of the rooms.
Is there a way to do this other than having to delete all of them then put them back in alphabetically.
Hi Robin,
When you say “Change the order” are you referring to a listing where all the rooms are displayed? If so you can set a listing widget to order by any field that’s included in the listing. It will normally default to the Record ID for the room, but if you want, for example, to sort the rooms alphabetically by Room Name, you can set this in the listing widget settings pane on the right hand side in Build Studio. Does this help?
Best Regards,
Mark Pearson - AppShare Manager
Hi Mark,
It’s not a listing widget but a Booking Calendar so you can see the bookings in a day
There isn’t an ordering to this kind of widget like there is for a listing widget.
Is it possible to sort using the record search filters? I haven’t used these before and don’t know the format of the return.
Regards,
Robin
