Case reference - best practice
Hi has anyone done any research into best practice for creating case references
Is anyone willing to share what they are using for case references patterns/formats
We are thinking
A-BUSPAS-1
Apply for a bus pass and incrementing number on the end, trying to make it readable, mean something to customer and service areas
Or just using random alphanumeric codes for each service - incrementing, keeping it short and readable
DRFS-1
I’ve seen other examples from central government
Passport application Reference: PEX followed by 10 digits
Any advice would be appreciated, thanks
As part of building an app we come up with an acronym to represent the app, which we prefix most component names with (think this was started when there was a limitation to the tagging system that made this necessary, and now it’s just habit but still somewhat useful) and so usually the reference uses that as the prefix and then an incrementing number. Sometimes we use a different prefix that might make a bit more sense. I think we sometimes start at 1000 mostly because it “looks better”.
we tend to avoid using special characters (forward slashes, dashes, etc.) and just have it all in one word in a single string, with the prefix being an acronym for the service if its long enough, and the ID incrementing from 1. it’s unlikely but it avoids regex edge cases and makes payloads for API calls etc. a lot simpler
