Composite - Add Interval - Dynamic field
Make an option on the Add Interval that you can add a field from that object/related object to use so your interval dynamically calculated.
Currently having to use a timestamp + duration composite, with the duration multiplying an integer (for year) by 365.24243600
Hi Glyn,
Thanks for this good suggestion.
In the context of all “Add interval…” and “Subtract interval…” Composite functions, we will aim to allow Build Studio users to specify the “Interval value” setting as a field path, as an alternative to a constant value.
