Regarding Application packaging.
Is it Possible to include the following in future releases: regarding the Converse Desktop Application.
Add an optional “command line option” that allows us to specify the installation directory.
We need this so that it’s possible to install 2 versions at the same time otherwise they overwrite the
last version. -
Start icon name to be adjusted to include the version number so that different versions can be
differentiated.- If this was included as well as the option above, no additional packaging work would be needed
and it could go straight to the deployment options.
Can we also ask what other companies do instead of having 2 versions (when Upgrading the App to include change control) of the software on devices. Perhaps there is a better or recommended process that we should be following.
