Create 10.4 Code Studio improvements
Create 10.4 contains a bunch improvements to Code Studio so i thought i would give you all a heads up with what they are:
  • For widgets, presenters and wrappers, your server-side JavaScript can now be modularised into multiple files by using CommonJS require() syntax.
  • It is now possible to call event actions, data processors, field processors and record selectors from the server-side JavaScript in any other component.
  • The Build Studio configuration of themes and data choices can now be interrogated from code.
  • Handy new functions all you to add, remove, clear and replace record relationships.
  • Functions have also been provided to add and remove records from event-based subsets and check their subset membership.
