Dark mode - Liberty Create
Is there a way to enable or add dark mode? If not, is this something that might be added in the future?
Thanks!
HI Raphael,
Liberty Create doesn’t offer a Dark Mode out of the box, however, you do have the ability to implement your own Theming, to which you can implement a dark mode for your applications.
You would need to create a theme pack along with the necessary early and late stylesheets.
If you message me at ryan.devine-davies@netcall.com, I would be happy to jump on a call, I may be able to share a starter theme with you.
For your own personal use you could try using a browser extension like Dark reader: https://darkreader.org/ though it probably wont be perfect. You could try putting in an idea for a native dark mode, but I expect the amount of effort involved to implement and maintain the feature would far outweigh how much actual benefit it would provide for most people.
