Enable rules to have multiple responses
There are so many times that multiple actions need to be taken as a result of one event. Currently, for each action, you need to create a separate rule. It would be useful to be able to have one rule (with one trigger) that has multiple responses.
This would help to organise rules and de-clutter the rules list.
Hi Angela,
Thank you for another good suggestion.
We have had that suggestion before so we need to give it some serious thought.
We are also toying with the idea of how we could make the rules more visual, both for building and exploring.
In the meantime (as you probably know) there are a couple of things that might help:
  • You can duplicate a rule before renaming the changing the action (to speed up creating multiple rules with the same trigger).
  • Viewing the Siblings tab gives a view of all rules with the same object and trigger event (and from here those rules can be reordered).
