When using fragment_presenter.set_setting('','')
is it possible to reference a property in a sub array ?
Array
[message_offline_mode_unique_lookup] =>
[wrapper] => 7
[presenter] => 75
[label] => Mandatory Conditional
[hint] => This shows the percentage of mandatory conditional fields completed correctly.
[required] => 0
[nonautoinput] => 0
[interactive_column_visibility] => disabled
[presenter_settings] => Array
[progress_bar_width] => 50
[progress_bar_percentage] => 1
[color] => success
[progress_bar_range] => 0-100
[progress_bar_min] => 0
[progress_bar_max] => 100
[display_on_small_devices] => 1
[display_on_medium_devices] => 1
[display_on_large_devices] => 1
[callback] => CSC0000193FEFDF1
[message_offline_mode_callback] =>
[custom_css_class] => no-table-header
For example I want to set “color” on a progress bar ?
Ive tried the obvious things but nothing seems to work for me.
