Input type not changing in custom presenter
I’d created a custom presenter a couple years ago for integers that puts the input type as number. I’ve recently uplifted the application to 23.1 and this has caused it to break.
It still has the min and max attributes being assigned properly, but the type is just staying as text.
Has anyone ran into this issue before or know why this could be happening?
Many thanks,
Ewan
Hi Ewan, I am just taking advice on this and either I or someone else, will get back to you as soon as possible.
Regards - Mark
Hi Ewan, I will message you with the contact details for someone who will help with this. It is probably due to the Vue version upgrade.
Regards - Mark
Hi Mark, thank you, I did think it could have been something to do with Vue
Yes that was my first thought too. Hopefully it’s a simple fix. Adam is the man to help you resolve this matter. Sorry it took a while to get back to you but we’re all very busy on various projects right now. Hopefully this will be a quick fix. Regards - Mark
