Liberty Create - Data Types - Usage counter on choice options
Hi there,
Is it possible to have usage counter on data types (choice) options, more for when creating a reference via code studio.
This would safe guard any choice options if deleted to not break references.
Regards
Hi Liam,
Good idea.
In the same way we have an “Info” popup dialog for properties and relationships inside the view of an object, we could similarly provide an “Info” button beside each Choice, revealing its usage.
Noted for future change.
Thanks for the suggestion.
Hey Paul
Yeah I have got into the habit of manually checking but to have the Info popup would be very very useful.
Thanks again
