A quick question I hope.
When I display a list of object data, if any fields are empty, they’re displayed as “-”. This also appears in the downloaded .CSV data if the list is configured with a download CSV option.
Is it possible to remove these “-” and instead show a " " instead?
Hi @camsd047 ,
Yes, there is a way of doing this
You can make a change within your build labels for empty values, but this will be platform-wide. If you would like to apply these changes, go to Build Studio > Locale > Labels. Then click on the System tab and search for the label default_display_value_when_empty.
You can then change the value as you wish, which in your case would be changing it to a blank space.
Hope this helps
Morning Ali, would you mind if I submitted this as a change request please, I think changing the empty value labels in the UI is too high a price to pay to have the download csv work correctly.
Hi @adam.mills ,
Of course!
raise something in the Community Ideas - It would be nice if we could control it within the Import/Export file types which would be more useful and isolated from the rest of the UI.
