Hi all
I’m sure i’ve previously seen a feature to convert a remote object into a local object, but i’m struggling to find it now. Has this been removed or am I looking in the wrong place?
Kev
Hi all
Kev
Afternoon Kevin,
If you delete the Object Connection, the Object itself will remain and become local. Ensure a full sync of records is done first maybe to ensure it’s all up to date.
You can delete the connection from the Object Connections panel under Data Exchange.
Thanks Adam, will try tomorrow, we are doing this in an app set up especially so no damage can be done!
