Users across Create Instances
If you are synchronising users across create instances (and using SSO for logins) …
This is using API calls / functions etc rather than local / remote objects …
Typical example might be creating a user in one instance then pushing it out to a couple of others …
How do you deal with things like security questions / answers, passwords and 2FA configuration between the various instances ?
I’m kind of assuming you don’t typically need to sync ANY of this for SSO purposes as the user is expected to always login initially to the “hub” location the account was created in so they can configure their own configuration as they wish. Do you simply suppress all account management capabilities in the “spoke” systems - so effectively no My Details, No Settings etc and only allow those on the Hub instance ?
There after, the auto SSO would handle future logins and Forgot my Password scenarios so again - all should be good ?
Forcing them to go “Home” would be an option for account management but just trying to figure what other people might have done in the past.
I might allow some limited updating from the spoke instances but probably only basic contact information rather than anything security or permissions / access etc which would be controlled centrally.
Hi Haydn - broadly yes, if you have a central hub that is the ‘source of truth’ then the simplest thing should be for that to be the only place the details are updated (and dispersed from). When accessing a spoke or satellite application, it can call home for SSO authentication, and/or to retrieve account details (name, user role, linked teams etc (or those metadata could be pushed out by remote object / API in real-time updates)).
If the spokes use SSO, with the central app as the server, then security Q&A, passwords etc don’t need to travel - they’re never being used.
If you have more than one spoke, and users can update details, then you run the risk of conflicting data. It might not be material of course, but I imagine it’ll cause confusion at some point!
Create can be challenging in totally suppressing the My Details/Settings pages etc, but you should be able to hide them or make them read-only I think.
Scott,
Yeah broadly what I had in mind.
Thanks for your response - at least I’m not going too far left field :rofl:
Haydn
