Validation using 2 instances of the same date and field
I am currently making a validators that uses the same default field “date created” to search a list. the issue is since there is 2 instances of the same field it only pull across 1 reference of the field so i am unable to use the 2 values for the validation check. Can there there be a way to use 2 instances of the same field in a validator in code studio.
Hi Travers,
I have answered a similar question here:
Does the suggested temporary solution there help?
