If you are a watcher of the Coming Soon category, you will have seen @dave.amps writing about the new Test Studio feature coming out in Liberty Create 10.4.
The Test Studio is a brand-new feature added to the Liberty Create solution enabling builders to test their builds as they progress. It allows you to drill down to every level of your build, stop and start tests, slot new tests between others and more.
If you haven’t already done so, have a read and let Dave know what you think.
