Hi there, could it be made so that an authenticated webpage can be used as the destination in a map widget?
Do you mean when clicking on a pin?
At the moment you can open a popup page when clicking on a pin. That popup can show details about the selected record, including an authenticated wbepage link, if that helps.
Hi, I also need this functionality. I don’t have the option to use a pop up for some reason
we are on 2021.3 as we are using Citizen Hub.
The popup option is available from 21.4 unfortunately.
