Auto reference upper limit value
Hi All
We have case reference data types using the auto reference as a base format with an incrementation of 1 and one of our applications has reached 6 figures.
Can anyone tell me what is the upper limit value of the the auto reference ?
Many Thanks
David
Hello David, as far as I am aware there is no upper limit on the value in an Auto-Ref Data Type. I have reached out for confirmation, but please assume that this is the case, unless I report back otherwise. I hope this helps.
Mark Pearson - AppShare Manager
Hi David, just to confirm, the Auto-Ref is 255 Characters alpha/numeric, so you are WELL under any number you are ever likely to hit on that front!
Regards - MP
The upper limit on the numeric part is over 2 billion, so you have plenty of room.
Thanks a lot to you both. We have room for quite a few more cases !
David
