Hi all,
We have two button clusters ‘Button Cluster Top’ and ‘Button Cluster Bottom’. As the attached image shows, one is a Code Studio Widget whilst the other is a Form Widget. I am having some issues with getting the styling between the two of them to be the same so I am thinking the solution would be to turn Button Cluster Bottom into a Code Studio Widget.
How would I go about converting the Form Widget into a Code Studio Widget or is there an easier way?
Thanks!
Craig
