Hello,
Just wanted to share a piece of useful code which allows you to access an objects schema (details, properties, attributes and relationships) by using a object reference .
// Create a new mats.record instance with parameter of 0 to get access to the record.schema method
var record = mats.record(0);
// Getting the object id via a mats object reference
var object_reference = mats.ref('object_reference');
// Passing a object reference to the schema method
var schema = record.schema(object_reference);
// Object details
var details = schema.details;
// Object attributes
var attributes = schema.attributes;
// Object properties
var properties = schema.properties;
// Object relationships
var relationships = schema.relationships;
mats.log({
details: details,
attributes: attributes,
properties: properties,
relationships: relationships
