Is it possible to use the replace composite function to replace commas with carriage returns (so a comma delimited list looks like a vertical list) or is this something I will need to do in a code studio presenter?
Kevin,
As you say there is no option to do this work with Composites as it stands.
I will add it as an idea, but suggest an event action that creates a mutated version of your string in another property as the best answer.
If this value is to be shown frequently on screen or within lists, this will be the more efficient approach.
Let me know if you need any assistance in creating the event action.
Please support the idea here:
https://ideas.netcall.com/i/ideas/p/feature/vote/idea/view?context_record_id=5389
It’s just for display purposes so i’m hoping a custom presenter will do it, but may look at an event action if that doesn’t work. Thanks
