I’ve created a rule to create a pdf from an online form which I’ve created as an authenticated webpage. The rule does create a pdf but it only includes the last page of a 5 page form, what am I doing wrong?
Hi @CathyS,
can you confirm if you have your form set up as a single build page with the 5 forms as sub pages built into the main page?
Anthony
Hi @CathyS,
So it sounds as if when the PDF is generate only the last page meets visibility requirements, Is the PDF being generated on submission? If so what you could do is build a template page containing the submitted information in an Info widget rather than Form widget, so that when a form is complete it generates a PDF from the template which contains no visibility requirements.
Alternatively to save time you could make a copy of the current form page, remove the visibility requirements and use this as the template that you generate a PDF from.
Hopefully this helps,
Anthony
