An opportunity to post questions to those using the E-form Migration process
Regarding that question from Robin about the multiple selection chackboxes - this is a ‘Relation Ticklist’ widget, the selectable items have been created via a separate object related to the form’s ‘DATA’ record. This widget type allows for multiple selections and will create the relationships chosen
Hi, thanks for the call.
Would it be possible to get a copy of the slides showing the Process Map and Data Modal?
Hi @WilliamADC - here is the process slide. I will share the other documents @robinli took us through to the group
