Is it possible to filter/search the resources component of the booking calendar widget?
If I have 100 field technicians and I want to quickly check calendar availability for two resources. I would like to filter the names of the resources using search.
I have tried using the conventional search widget method as well as adding the resources to a subset and using the booking subset which is available on the booking calendar widget but none of these methods are working for me at the moment.
Kind Regards,
