Fragment Validator "Invalid format" message
I have added a fragment validator which is working as expected.
I would to change the Invalid format message that is shown to something more suitable to the user such as Please remove ‘{ENTER REQUEST}’ and provide a proper task description
Is this possible, and if so where do I set this message?
I couldnt find anything in documentation related to Fragment Validation setup.
Thanks JonathanFS
Whoops found it.
Help Portal
 * Fragment Validator: Fragement Validator - Task Description containing {ENTER REQUEST} is Invalid
return {
	 * @param {fragment_presenter} Fragment instance
	main: function(fragment_presenter) {
		//cs.log('*** Fragement Validator - Task Description containing {ENTER REQUEST} is Invalid ***');
		var value = fragment_presenter.get_value();
		if (value.includes('{ENTER REQUEST}')) {
			return {
				valid: false,
				error: "Please remove '{ENTER REQUEST}' and provide a proper task description."
		return {
			valid: true
FYI, there is also a simpler shorthand version where you can just return the desired error string. E.g.
return "Please remove '{ENTER REQUEST}' and provide a proper task description.";
