Public Webpage Styling
I’m sure its something obvious but …
how the xxxx do I override the narrow (fixed) width of the public webpages ?
Secondly - even though I have selected an appropriate theme reference - it seems like styles are not being applied exactly as I would have expected.
Titles for one are in a totally different colour to those ascribed in the theme is the basis for my question.
Everything just looks off and the sizes seem increased over what I would expect too …
Its definitely bringing in the relevant stylesheets though as I am using other bespoke elements from it just fine.
Haydn
Tables look exactly like their interface based versions but other “texts” are definitely iffy !!!
Button sizes are not respected either as far as I can see :man_shrugging:
Hey @Haydn.Haynes !
As this is quite specific to your app, I would suggest we have a look at your app & stylesheets together, does that work for you?
Meike
In the meantime @Haydn.Haynes - does this help?
You can create classes under the .webpage class as below:
.webpage {
button {
font-size: 48px;
yeah my bad …
There’s a bunch of errant css in our stylesheets which I will need to purge !!!
Thanks all.
