Hi, wondering if anyone has managed to use regex to validate What3Words in a text field in Create?
I have been trying all morning without success!
Henry
Henry
Not tried it personally but there are a few examples online of possible solutions …
Our implementation of W3W actually does the lookup though so we don’t need to validate it in this way.
Morning Henry,
Are you familiar with our what3words presenter on AppShare, or are you looking at a different use case.
https://community.netcall.com/appshare/i/what3words-latitudelongitude/
var regex = /^\/{0,}(?:[^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+[.。。・・︒។։။۔።।][^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+[.。。・・︒។։။۔።।][^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+|[^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+([\u0020\u00A0][^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+){1,3}[.。。・・︒។։။۔።।][^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+([\u0020\u00A0][^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+){1,3}[.。。・・︒។։။۔።।][^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+([\u0020\u00A0][^0-9`~!@#$%^&*()+\-_=[{\]}\\|'<,.>?/";:£§º©®\s]+){1,3})$/;
if (regex.test(text))
print(text + " is the format of a three word address");
else
print(text + " is NOT a three word address");
This is the recommendation as given by what3words.
A simpler interpretation would be /[a-z]+.[a-z]+.[a-z]+
This optionally allows for the 3 /// as well as three words separated by periods.
Thanks Adam, that simpler version has done the trick ![]()
Thanks for your help, Haydn ![]()
