Is it possible to specify a default height for a property field within interface/webpages?. Within the field settings we can specify a width but not height.
When using a text multi-line field our users have asked if the input box could display larger on screen. We looked at implementing with CSS however no success!.
You can with CSS, override any element within Create.
The css can be added within applied Early and Late Stylesheets under Theming.
Make sure the theme you are modifying is the active theme for your interface.
There is an eLearning course available if you wish to familiarise yourself.
You will need to use !important to ensure your override is utilised.
Alternatively if it is just individual fields, each field has the ability to have a Custom CSS class added.
Made a tweak and got it to size correctly now. The height however is fixed, would there be a way to have the effect that by default the textarea is a certain height but it would still expand if more lines are added beyond what is already there?
