Hi ,
I’m trying to control the display of elements on an Information Template with no base object using a Global Switch in a table cell. The option is there to select the Switch, but it does not work. It does not work on a ‘div’ element in the template either.
The Switch works fine on other widgets.
Thanks for any help.
Mark
