Text type composites in Subsets
I’ve just noticed that I can’t select Composites of type Text in subsets. Is this a bug or is there a reason for it?
The workaround is to create a rule which saves the composite in a property, I’d prefer to use them directly if possible.
Hi Craig, we asked this a while ago but it doesn’t seem to be possible. Support’s answer was:
Text composites cannot be used in subsets because determining whether a record is in a subset or not needs to be done purely in a database query.
Thanks James, the workaround has been promoted to primary solution. :1st_place_medal: :grin:
