I am creating a simple request form that I need to make available to non-logged in users. I have been advised to create a webpage (public) with a webpage link to a webpage (authenticated) to make things more secure.
I have found that the weblink won’t work (it is greyed out and hovering over it displays record not available) unless I tick autocreate record in the Basics of the webpage.
I would prefer to avoid this page creating records as I suspect that it will result in an abundance of blank records in the system.
Is there any way of redirecting from a webpage (public) to webpage (authenticated) without creating a record on the first page?
Thanks in advance,
Jane
I don’t think so, as an authenticated page must have a context ID.
Your public webpage should have no base object, the form widget should have a base object.
The following auth page should have the same base object as your form widget on the public page, then it should all work
Thanks for the quick reply.
That’s how I have it set up - but was just hoping I could avoid the inevitable unnecessary records.
Thanks again,
Jane
We often use rules to clean up records that are created unnecessarily (for example where we include a file upload on a page in a widget group with a parent record) we will do a rule that deletes record if the file attribute is empty
Another thought, are you collecting data on page 1? if not, page 2 could be a public webpage too (not sure if i’m understanding your situation).
We’re not collecting data on p1, it’s purely a redirect.
With the public webpage - I can’t get the link to work if there is no base object on the page. It only works with a base object and the auto create record option ticked. That seems to contradict what you thought would work - have I misunderstood?
Again, thanks for the feedback on this.
Jane
Yes! That is what I was hoping to achieve, but with the second page as authenticated.
Thanks for your help Kevin.
Jane
