Hello, is it possible to pull the interaction ID relating to an agent evaluation into the reporting output? many thanks
HI Conrad, you would need to use the Evaluations report to view this.
This is separate from the interactions report.
Hi Jonathan, many thanks for getting back to me!
I assume that an evaluation is always carried out on an interaction? E.g., a call is listened to and assessed? If that’s the case, what I need is that interaction ID to be visible in the Evaluations report. That way I can link it to all the other data about the interaction (skill, activity code, team, etc.) which would be a massive boon to our reporting.
Many thanks
Hi Conrad, that is a fair request. Can you add this to the Ideas Portal so it can be logged and looked at.
Many thanks.
Excellent - many thanks Jonathan - I’ve raised this now.
Much appreciated
