Agile PM2 with Ideas and Feedback Module - 2023.3
We want to install this in our environment but we are on 2024.3. Is there a plan to upgrade this or a way that we can install it on 2024.3?
Hi Richard,
Thanks for reaching out. Please leave this with me and I will investigate the matter further for you. I’ll report back as soon as I have an outcome for you!
Best Regards - Mark Pearson
AppShare Manager
Hi Mark,
Do you have any idea of timescales for this?
regards,
Richard
Did you try and install module from 2023.3 to the 2024.3, as I installed code/presenter/widgets from earlier versions and it has worked? Worth a try maybe.
Hello Everyone, we are looking to upgrade Agile PM. I’m just waiting for a suitable resource. I will advise you in a few days as to the timeline.
Best Regards ,
Mark Pearson - AppShare Manager
