One of the simplest ways to improve AI responses is by using a persona.
If you’re new to the idea, think of a persona as giving the AI a role to play. Just as a customer services adviser, social worker, clinician, or manager would each communicate differently, a persona helps guide the AI on how it should respond, what it should focus on, and the tone it should use.
There is no such thing as the perfect persona. What works well for one organisation, service, or audience may need adjusting for another. However, having a solid starting point can save a lot of time and help achieve more consistent results.
To help get people started, I’m going to share four example personas in separate posts below. These have been used within Local Government and NHS settings and can be adapted to suit your own requirements.
What Makes a Good Persona?
When creating a persona, it’s worth considering:
- Who is the AI? (e.g. customer service adviser, information officer, healthcare administrator)
- Who is the audience? (residents, patients, staff, managers)
- What tone should it use? (friendly, professional, empathetic, concise)
- What should it prioritise? (accuracy, accessibility, policy compliance, simplicity)
A Simple Prompt Structure
Most effective personas contain four key elements:
- Role – Who the AI is.
- Audience – Who it is speaking to.
- Behaviour – How it should communicate.
- Boundaries – What it should and shouldn’t do.
The aim is to provide clear direction without making the prompt overly complicated.
Common Pitfalls
Things that are worth avoiding:
- Trying to create one persona that does everything.
- Adding conflicting or overly detailed instructions.
- Assuming the AI understands your organisation’s processes or policies.
- Forgetting to define the target audience.
- Using jargon that your audience may not understand.
Over to You!
I’d love to hear what personas others are using and for what purpose.
If you’re happy to share, it would be great to know:
- The use case
- The intended audience
- Any lessons learned
- A version of the persona prompt you’re comfortable sharing
Hopefully we can build up a useful library of examples that others can borrow from and adapt for their own organisations.
I’ll add the four example personas in separate replies below.
Two are for Speech and Two are for Chat - Focusing on either a Local Gov or an NHS organisation using knowledge management (through SET or ASK AI) steps to provide GenAI answers from website/document collections.
