Hello, if we delete a busy code from Netcall, does this remove all historical data associated with it?
Any help would be much appreciated thanks ![]()
HI David, the code will still be reported on if select all is selected in the report, but you can’t then select the busycode to report on from the drop down list.
Hope that makes sense.
