I am having some issues with specific properties on a data object on Central named Task Template
The following properties are [i] failing on import without error or [ii] not duplicating when rule is fired….?
- Group Text, Single line
- User Text, Single line
- Assign User - Applicant Boolean
- Assign User - Case Owner Boolean
- Assign Group - Case Group Boolean
For the import I can see that values in the export file, but they arent imported an no error is shown, I am importing another Boolean in this import just fine.
For the Duplication Rule, it duplicates all the data including all relationships, except for the 5 fields mentioned.
It seems strange to me that its the same 5 fields are acting strange? Has anyone seen anything like this before.
Here is Duplication rule config
(I did try to fix by changing to Selective and selected all fields, inc. fields not duplicating)
Here is Export Template
(First 16 fields are Task Template properties, 17-19 are relationship)
Here is Import Template
JonathanFS (East Hants DC)
