I’m creating a set of event actions which each perform a calculation using the same JS library. I would like to be able to load the library file (from asset?) rather than have to copy/paste the code into each of the event actions.
I’m not sure if JS modules functionality works inside Create, but it would be useful to be able to use the export/import features to load commonly used libraries.
Is this currently possible?
Morning Chris,
Unfortunately shared libraries is not yet possible, although it is on the wish list.
I’ll add it formally to the ideas area and you can vote it up to show your support.
Many Thanks
Adam
Please support this idea if it would be of interest to you.
https://ideas.netcall.com/i/ideas/p/feature/vote/idea/view?context_record_id=3317
