CSS Tricks: Navigation fade
I’ve just been playing with something to add a little user feedback on navigation. It’s kinda cool so I thought I’d share it.
You will need to add some classes into your theme CSS:
@media (min-width: 992px) {
  .PAGETABS, .SUBTABS {
    ul.nav:hover a.nav-link:not(:hover) {
        opacity: 0.5;
    a.nav-link {
        transition: opacity 0.2s;
What it does:
When you rollover/hover over your page/sub tabs, the unhighlighted tabs dim in opacity.
ScreenRecording20190212at1
What is the code doing?
First off, I have chosen to wrap the CSS in the @media declaration which, in this case, is set to only affect screens which are more than 992px wide.
Then we have a little SCSS. I’m wrapping two classes inside “.PAGETABS, .SUBTABS” which process all the contained classes to be available to both the pagetabs and subtabs. It’s a bit of shorthand that saves us writing the same code out several times.
Next the good stuff.
ul.nav:hover a.nav-link:not(:hover) {opacity: 0.5;} says:
If the mouse is hovering over the navigation (ul.nav:hover) then, set the opacity of the links (a.nav-link) that are not being hovered over (:not(:hover)) to 50% opacity (opacity: 0.5;).
I confess that it is a little mindblowing. The second class is much easier to understand :slight_smile:
a.nav-link {transition: opacity 0.2s;} merely says:
Set the transition speed of the opacity change to 0.2s
What next?
Well, this opens up all sorts of ideas… you could set all the links to have coloured bars below them which disappear if they are not being highlighted.
        opacity: 0.5;
        border-bottom: transparent;
    a.nav-link {
        border-bottom: 2px solid blue;
Paul Edmonds
UI/UX, Matssoft
I’ve been looking to do something like this for ages, this has really helped me!! Thank you so much Paul.
Nice one Paul! An awesome feature to add onto our applications to give a nice UI experience :slight_smile:
This is really great feature. Is this something that can be made available to our customers via the App Store so that this can easily be found in the future?
Giuseppe
I’ve applied this to a deployment on 10.1 and confirmed works, good feature to add, thanks!
