Is it possible to display cancelled bookings within the calendar widget alongside the booked ones, possibly in a different colour?
Ewan
Ewan
Hi Ewan,
We did something similar to what you are suggesting in one of our accelerators i.e. Colour coding the different types of Bookings in a calendar, please check the screenshot below.
For more details you can download the following app using the link below, install it and see how it was done. I can assist you further with it if you require.
https://community.netcall.com/appshare/i/calendar-bookings-with-callmeback-accelerator/
I hope it helps.
Regards,
Asif Kundi
