DocuSign and Liberty Create
We have a requirement to use DocuSign for some authorisation processes within Netcall.
I need to add a docusign signature box onto a netcall form, and to ensure this is filled out before allowing submission.
Is this possible to use in Netcall?
…and if so - any pointers be very helpful.
I see it has a Rest API but know nothing more.
Jonathan FS
Hi @JonathanFS, did you get an answer through other channels, or otherwise figure out how to satisfy your requirement?
Jared
Hi Jared, Previously there was a Docusign integration within Create but it wasn’t used and therefore ended up being removed, it is however still possible to integrate with docusign, additionally we do also natively support the ability to capture electronic signatures without the need for Docusign.
