Easiest way to fire an event when a Link is clicked
Is there an easy way to fire an event when a link is clicked.
Currently this is where I’m at…
  • Option 1: Build a presenter
    I’m writing a presenter at the moment, but its taking more time than I want.
    I’ve got it to trigger the event, but its not opening the Link :frowning:
  • Is there an existing presenter to do this? or something similar I can amend.
  • Or do I have other options?
Many Thanks
Could you use the action link element and then set the Redirect after action value? Or for your presenter could you use cs.redirect after the cs.fire_event?
Thanks, but I want to stay on the same page and open the link in a new tab.
However I did build a new presenter titled Fire Event from Link which is working as I want.
So I will leave the code here for the full VUE.JS component as this may help somebody else in the future. I’ve not doubt it could be written better; suggestions welcomed.
main.js
/* Main server-side presenter code */
Author:         JFS
Date:           12/06/2026
Developed By:   East Hampshire District Council
Presenter Name: Fire Event from Link
Version:        v1.0
Information:    Presenter to use on Base Format: Link
                User can i) select an event to fire and 2) select a field path to a Link property.
                - Event: Send Message
                - URL field: https://www.google.co.uk/
                When user clicks this link, the Link is opened in a new window, and selected event is triggered.
let debug = true;
return {
get_template_data: function () {
    const recordId = presenter.get_fragment_record_id();
    const record = cs.record(recordId);
    if (debug) cs.log('\*\*\* Presenter: Fire Event from Link v1.0 \*\*\*');
    if (debug) cs.log('> recordId: ' + recordId);
    if (!recordId) return false;
    // URL Field --> URL
    let url = null;
    const urlField = presenter.get_setting("url_field");
    if (debug) cs.log('> urlField: '+urlField);
    if (urlField) {
        const parts = urlField.split(':');
        const fieldPath = \`:${parts\[1\]}\`;
        url = record.get(fieldPath);
    if (debug) cs.log('> URL: ' + url);
    const eventID = presenter.get_setting("event");
    const reloadPage = presenter.get_setting("reload_page");
    return {
        recordId: recordId,
        url: url,
        eventID: eventID,
        reloadPage: reloadPage
action_fire_event: function (params) {
    const eventID = params.eventID;
    if (!recordId || !eventID) {
        cs.warn("Missing recordId or eventID");
        return { success: false };
    if (debug) cs.log('> Firing event: ' + eventID);
    cs.record(recordId).fire_event(eventID);
    return { success: true };
get_settings: function () {
    return {
        event: {
            main_label: "Event to Fire",
            base_format: "choice",
            choices: cs.build_choices('event'),
            settings: { required: true }
        url_field: {
            main_label: "URL Field",
            base_format: "field_path",
        reload_page: {
            main_label: "Reload Page",
            base_format: "boolean",
            settings: { default_value: true }
frontend.js
/* frontend JS */
Author:         JFS
Date:           12/06/2026
export default {
props: [“recordId”, “url”, “eventID”, “reloadPage”],
mounted() {
console.log("Mounted recordId:", this.recordId);
console.log("Mounted url:", this.url);
console.log("Mounted eventID:", this.eventID);
console.log("Mounted reloadPage:", this.reloadPage);
methods: {
fireEvent() {
  console.log("Click fired");
  this.trigger_action('fire_event', { eventID: this.eventID }, (e) => {
    if (e.result === "success" && e.response.success === true) {
      console.log("Event fired successfully");
      // open the policy link in a new tab
      if (this.url) {
        window.open(this.url, '\_blank');
      // reload calling page (only if enabled)
      if (this.reloadPage) {
        window.location.reload();
    } else {
      console.error("Event failed:", e.response);
main.html
<a href="#" @click="fireEvent">Read Policy {{ recordId }}</a>
styles.css
a {
color: #0078d4;
text-decoration: underline;
cursor: pointer;
a:hover {
color: #005a9e;
config.json
“main”: “main.js”,
“frontend”: {
"vue": \[
  "frontend/frontend.js",
  "frontend/main.htm",
  "frontend/styles.css"
All the best
Looks good to me. You might want to move the “if (!recordId) return false;” line in main.js above the const record = cs.record(recordId); to prevent it throwing an error/problem in newer version of create if there is no recordID
Good spot, Thanks Ali.
I did add it, but in the wrong place - doh.
