Hi there,
I’m trying to create an integration with GovNotify which requires a JSON Web Token to be generated before being sent in the API. How would you do this?
Thanks.
Hi there,
Thanks.
Hi Luke,
Firstly, welcome to the Netcall Community, I see you are a first time poster. I will find someone to get back to you on this matter and hopefully steer you in the right direction.
Best Regards.
Mark Pearson - AppShare Manager
Hi, two things…
Firstly Code Studio has methods for encoding and decoding JWT. So you could use an Event Action, for example, to generate the JWT and save it to a property field ready to be then used in an API call.
But secondly, depending what you are trying to achieve, Create has some integration with GovNotify already. So if it’s for outbound SMS you might be able to do this out-of-the-box, with a little setup on and providing Netcall your account details. You can find some details here: https://docs.netcall.com/docs/liberty-create/2026.1/build-studio/communications/gov-notify
