In 10.4 how do I make it so that complete stage can only be clicked by a user with a specific role - i’m a bit rusty and i think this may have changed with permissions coming in
TIA
TIA
Hi Kevin, In 10.4 you can restrict a stage to be completed (or regressed) by a user with a specific privilege. From the process map, click the stage to be restricted, the options of assigning a completion or restriction privilege can be selected from the panel on the right.
