I’ve created a row of checkboxes taken from the radio button choice classes which are linked to multiple boolean values but for some reason it won’t toggle when I press on them.
I haven’t found any code for checkboxes and I also can’t seem to send over a true value to have the checkbox automatically filled
the v-if means if there are less linked settings it can ignore the
I have tried the v-model as toggle, switch_value and choice5.
<div v-if=“choice5_label” class=“radio_choices-row”>
<label class=“custom-control custom-checkbox form-text”>
<input :name=“mats.input_name + ‘[choice5]’” v-model=“toggle” class=“col-form-value valid_boolean custom-control-input input_boolean custom-checkbox” type=“checkbox”>
<span class=“custom-control-indicator”></span>
<span class=“custom-control-description”>{{choice5_label}}</span>
</label>
</div>
Robin
edit: I had an interaction-disabled taken from a higher div. Removing this has allowed for toggling of the checkboxes. I still can’t however take in true from get_template_data and show it
edit: solution found adding checked=“checked” and v-if=“choice5” and another without for v-if="!choice5" worked
<input v-if=“choice5” :name=“mats.input_name + ‘[choice5]’” v-model=“toggle” class=“col-form-value valid_boolean custom-control-input input_boolean custom-checkbox” type=“checkbox” checked=“checked”>
<input v-if="!choice5" :name=“mats.input_name + ‘[choice5]’” v-model=“toggle” class=“col-form-value valid_boolean custom-control-input input_boolean custom-checkbox” type=“checkbox”>
