Hi all,
I am trying to import some python packages that I need for advanced document analysis and ran into some troubles I was unfortunately not able to resolve myself.
As explained by you in another issue I changed my python path to my anaconda base environment using
python_path = user_path + '\\Anaconda3'
sys.path.append(python_path)
sys.path.append(os.path.join(python_path, 'Lib'))
sys.path.append(os.path.join(python_path, 'Lib\\site-packages'))
When I now try to import
from docx.api import Document
everything works. However, when I then want to read the document, an error occurs:
word_doc = Document(file)
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "docx\api.py", line 25, in Document
File "docx\opc\package.py", line 128, in open
File "docx\opc\pkgreader.py", line 32, in from_file
File "docx\opc\phys_pkg.py", line 101, in __init__
File "zipfile.py", line 1258, in __init__
File "zipfile.py", line 1321, in _RealGetContents
File "zipfile.py", line 259, in _EndRecData
ValueError: I/O operation on closed file.
This does not happen for my local python interpreter (in the same environment).
When trying to solve the problem via
with open(file, "r") as f:
I also get an error:
File "<string>", line 16, in read_table_word
File "zipfile.py", line 1325, in _RealGetContents
zipfile.BadZipFile: File is not a zip file
During handling of the above exception, another exception occurred:
File "<string>", line 26, in read_table_word
AttributeError: '_io.TextIOWrapper' object has no attribute 'split'
I have similar issues with a couple of packages (for example, requests or spacy). All of them work with my local interpreter but not within liberty RPA.
Is this just a compatibility problem that cannot be resolved, (i.e., I would have to find another workaround)? Or am I missing something?
Also, just as I side note: In case you are wondering why I’m not simply using the built-in read word file node: I wanted to directly extract the tables of the word file
My environment has python 3.9.7. If you need any other info on packages etc. please let me know
Thank you,
Michaela
