Before I report it as a bug, is there a reason that all the heading options are invisible on forms? The text is there but it appears to default to white (the background colour) and there are no options to change this unlike with other text fields, it’s very frustrating from an aesthetic point of view!
Hi Jo,
Just to clarify did you mean the actual ‘Heading’ element on a form (‘Heading 1’ in the screenshot below)
OR
the heading OF the form (Title field and set to ‘Form 1’ in the screenshot below)?
Regards,
Asif
Both, it’s ok Sean resolved it with some CSS magic
Ok brilliant, if you can share some end result screenshots with the Community (or CSS snippets) that’d be great.
