Does anyone have any advice about using a subset indicator in a code studio widget? It doesn’t seem to be available as a base_format.
Mark
Mark
Hi Mark,
To create a setting on widgets/presenters to consider a subset, you need to use the format of “subset”
subset1: {
main_label: "Show When In",
csid: "subset_path_1",
base_format: "subset"
This will show itself like this in the settings panels.
You can then use the data from this setting in other functions such as:
record.in_subset(presenter.get_setting('subset1'))
Great! Thanks Carl: widget working ![]()
