Hopefully, a quick and simple question.
Our UX designer wants checkboxes to be displayed with the label on the right (the way they are in the builder configuration panel).
However, I’ve tried every combination of wrappers and presenters and scoured the config, and I can either get it to show the label on the right, above, or not at all.
Is there an easy way to designate where you want the text to appear for a checkbox?
May thanks
Stephen
