Hi all
Liberty Connect is Netcall’s conversational messaging and chatbot solution. It allows you to engage and assist your customers across your web site, web-based products and social channels. You can also extend your capacity by enabling intelligent automation to provide on-demand context and behaviour-driven self-service.
Connect 2021.1 is live, and the supports documents are now available in the Documentation portal. Take a few minutes to find out what you can do with Liberty’s premier conversational messaging and digital engagement solution.
Just go to the Documentation tab in the Community and choose Liberty Connect from the Select Product drop-down.
Take a look and tell us what you think.
Cheers, Tony
