Mitel SIP interop guide
Is there an up to date interop guide for configuring SIP trunks with a Mitel 3300? I need the recommended Mitel SIP peer configuration settings.
Thanks.
Hi @cbuonanno Not sure much has changed over the years, if you have a particular project you are working with Netcall on, can you contact the Project Manager who will be able to assist, if not then the Netcall account manager. If you have a particular issue you are trying to overcome do let us know.
Many thanks.
