Patch 2025.1.786 - no description
Can someone please advise why a patch would not have a description? Outstanding patch today 19/02/2026 2025.1.786.
Hi Susanne,
Thanks for reaching out. I have taken a look and the patch is “Fixed map widget label popup functionality in webpages”, I will raise internally that there is a missing label on this patch.
Thanks for confirming Carl.
Susanne
Hi @andrs3 ,
I can see that the patch name has been sorted internally now, but you may need to run the Pulse sync script for the naming to display. If you could run the Pulse script within Build Studio > System > Scripts, wait till it finishes running, then check again, you should then see the patch details populated.
Please do let me know if this doesn’t resolve the patch issue :slight_smile:
